Acrylic Photo Frame by hd8fdkd
http://filterforge.com/filters/9958.html
Very good idea, as there is lots of wood, metalic, textured or colored frames BUT not anyone that is as elegant and without any kind of additional things that does not modify the artwork as good as a Acrylic frame (as least from my own taste and point of view)
And this one seems to be very well done and it gives a very good effect and like it.
But I think there could be perhaps a problem when using it inside Photoshop as a plugin
I have made this examples and have got some errors
here the frame around gets nearly all black but the lower part also has the same error as above
This is using Photoshop CS5 and not CS6
hd8fdkd
NAO
Filters: 10
>SpaceRay
Oh...I found this error in "Diffuse" image. smile:dead:
But now, I solved this problem.
The cause of this error is that some of image alpha value had become less than zero by "Gaussian Blur".
I have submitted the fixed version.
Please wait the next version.
hd8fdkd
NAO
Filters: 10
SpaceRay, new version is now available. smile:)
hd8fdkd
NAO
Filters: 10
I have updated this filter on April 23rd.
In this version, it can make clearer outputs than previous one.
Good thing, thanks. I will see how it works
hd8fdkd
NAO
Filters: 10
>SpeceRay
Yeah, try it. smile:)
And...
Have you solved this problem?
