Dot Matrix LED Display v0.1 by fraglimit
http://filterforge.com/filters/10412.html
VERY well done, simple and wonderful. Curiously I was going to try myself or suggest something like this and now you have done it smile:)
Beautiful result can be get. Lovely. Like it much and fast too.
And here is close up detail
fraglimit
Thanks for your kind words. As a matter of fact i have been searching online for a filter that produces this effect and i found nothing, so i decided to make it myself smile:D
Thanks to you for making this filter. I have also been searching online and found one but is not the same as yours, that converts the colors to one color and is yours is better for me.
Close up
Real size
And this Marylin Monroe photo through your good LED display smile:)
And is even better on solid plain colors
in more detail
Fraglimit, I used to do this effect alot in photoshop using an action that I made, and now thanks to you I can change settings on it in a click of a button instead of editing the action.
Thanks!
fraglimit
Thanks for the positive feedback guys. I'm glad people find my filter useful. I'll continue to expand on the filter - got a couple of ideas for more features.
A good and useful filter for me deserves a positive feedback and I want to thank the author for it.
By the way, I have seen that is your FIRST filter, so again congratulations on making it.
Good, that you have further ideas for this, will be interesting to see.
CHANGE DOT SHAPE TO LINE SHAPE ALTERNATIVE?
I have a simple suggestion that perhaps could be useful if you like it, and that you could make the round dots like also the other model of LED displays that are a very little rectangular line, so it would change the shape.
Here is a rough example from this website of display technology
IT WOULD BE HELPFUL TO HAVE MORE PRESETS
I would suggest also adding more presets with different dot sizes from very small to large ones, as the new users could know faster what can be done without have to experiment with the settings.
fraglimit
Noted
Mongoose King
Mongoose King
Filters: 21
You hads the same thunking as me Spaceray. I already made this...
Release the Mongoose!
Mongoose King wrote:
You had the same thinking as me Spaceray. I already made this...
NO, Sorry, I am NOT AT ALL suggesting that fraglimit makes a RGB display filter, and is NOT like your filter.
What I have suggested is JUST to have an alternative to the DOT and replace it by a LINE shape, that is ALL, not any change in color as you have done.
I have put the example above ONLY to show the line shape example but not to change to RGB as you have done very well.
______________________________
Your example shown looks very well, is this a new filter you have made ?
Mongoose King
Mongoose King
Filters: 21
Ahh, you just mean the shape, I get you now.
I had the idea for separating the channels a while ago, was going to use it for a CRT style one, but the phosphors on a crt are in a more complex pattern.
Mongoose, I do hope to see your LCD screen filter in the library. Looks very realistic.
Mongoose King
Mongoose King
Filters: 21
I'll probably submit it in a bit. was trying to make like an actual screen effect option, like set in a frame, but doesn't look very good, maybe best to stick to the basic thing.
Why on the filter forge library website appears 8 presets BUT when downloading it only has TWO of them ?
I think this can be possible because the submit wizard MAKES them when submitting to the library BUT these are NOT included in the filter downloaded version, ONLY the ones that the author has created by himself, or I am wrong?
Mongoose King
Mongoose King
Filters: 21
Well, if there are less than 9 presets, it just fills the rest in with random stuff, like when clicking next variation. I doesn't add them to the filter though.
This filter has won one of my own SA Awards
Congratulations and thanks very much for creating this filter that are so creative, innovative and very well done. Love it much.
Kenyetta
I'm looking for a specific LED strip light...smd 5050 ?
I have found the exact strip light I need at V-LEDS WHITE STRIP LIGHT 12"
led flexible strip
My question is where can I find a similar part with the 12v led bulb same SMT/SMD led and identical design that is cut-able to any length. Most of the strips I find online are cheap and not nearly as bright.. Any ideas?
Boy, are you in the wrong forum! smile:D
