| Posted: February 15, 2012 3:01 am | ||||
Hello, This my real first filter.
Later when I have time to make them, I will put some good examples of what can really be done with this filter Also will put some tips and hints on how to get the most of this filter and make a short tutorial. As you can see in the presets it has many different combination and give many possible results. I am sorry that it has ONLY 20 presets available, as I could have put 40 of them as you can have many different combinations and get very different results combining all the settings and options. As said in the "About" tab, the choice of blend modes in this filter is VERY IMPORTANT and will change much the results. Experiment and and combine different settings and then try different blend modes and with or without crackles. Regretably the Blend modes do not have the names on them, and only numbers, but Please look at this list here below to know the corresponding number of the filters settings to the real name of the blend mode.
I have put the following thread asking to a way to put this names into the filter but is not possible How to show the blend modes without having a dropdown control option ? Hope you enjoy it and would be useful for you |
| Posted: February 15, 2012 3:14 am | ||||
Congrats on the first "real" filter
Hoping to see more. |
| Posted: February 15, 2012 3:56 am | ||||
Mardar
Hey SpaceRay, I found a glitch in this filter. When I make my tile I get this strange unwanted strip along the edge of the tile.
I think I found the problem. In your 5 color gradient the first and last setting are 10 and 90.
They should be set at 0 and 100 so you have a smooth wrap around for tiles.
You can test this to be sure I am correct. Other than that, I like this filter. |
| Posted: April 4, 2012 3:44 pm | ||||
I have seen that this filter has been awarded with an HU award!!
Thanks very much to all the users that have used this a lot and better that you found it useful and glad to have done it
OH! I am very sorry that I not seen this before and I could not fix it earlier, will now take a look at it and fix it as you suggested. Thanks for letting me know about it. |
| Posted: March 24, 2014 9:23 am | ||||
15 unregistered users.
