Interesting, cool, weird and nice effect, it looks like an chemical acid reaction, or like oil on water. Very well done. Very simple but very effective. Thanks
Another different version - You have thousands of possible variations !!
And you can add your own images and photos to see them through the holes of the chemical reaction and work as background
Here I have used as a background a black and white very cracked and peeling paint texture
And I tried the filter with a foreground (where the filter makes the effect) and used a simple red anemona flower photo and got this excellent and lovely effect that I like it much !!
Here is the original anemoma flower photo
Congratulations for the good map script and converting the above photo into what is seen below
And this is with some orchid red and magenta flowers with white milk in the back.
On this I did not use any background, the black is the frame of the photo that has been distorted nicely.
And this another example of great and lovely chemical style distorsion smile:)
this is also without any background added, just plain white
Congratulations again for making this beauty of filter
And what would happen if you make 4 different results with 4 different photo sources and then mix them toghether into only one using blending modes?
Well here is a quick and roughly example below.
I have not used any kind of background for this, just plain white
lipebianc
FFF = Filter Forge Fan
Wow! Really cool!
Spectacular examples, SpaceRay!
Here is another different example with other 4 different photo sources and mixed toghether
lipebianc wrote:
Wow! Really cool!
Thanks very much, glad you like them. This are just quick tes and examples, I know that if you choose carefuly some prepared photo to be used specially with this filter it will have even better results.
ERROR IMAGE CUT BY A VERTICAL LINE IN THE MIDDLE
ALthough now as it is not perfect, because there some problem in that on many or most (of the thousand variations) of the variation it happens that a big middle vertical line is cut straight, you can the error in the images 3, 4 and 5.
38 unregistered users.
