Good texture. Two suggestions -- I think making it somewhat less shiny will produce more realistic look, plus I'd remove green and blue-colored presets to avoid contradiction with the name "Molten Lava".
James
James
Filters: 46
Great texture, i also think its a bit too shiny though but looks great smile:)
Deathtop
Texture Master
It says this filter has 8 presets...
Yet only the default preset is available for me?
Stretched 2 Fit!
This filter was submitted back in the days of the presets being rendered for the website on FFs server end and not the filters creators computers end...So if you were to submit a filter back then with only one preset the other presets would automatically be rendered to fill the spots on the Filters Webpage as you see on this filters webpage...Even thou they are not actual presets in the filter...
So when you download a filter in some cases you will get that one preset because that is what the original filter author had submitted the filter with.....
Deathtop
Texture Master
@CFandM - Thanks for the detailed explanation. Basically making that carrot look fatter to entice the viewer! I guess I'll just have to create my own presets for it then. smile8)
I see you have an impressive amount of filters created here. Any tips, links or suggestions for a new Forger like myself?
Stretched 2 Fit!
Yep you are welcome....One tip is make nine presets... smile;) smile:)
I would say after downloading some filters look at how they were put together
and start taken them apart to see what component does what...Start with some simple
filters when starting off creating filters...You can get some awesome results with
only a couple of components...
Check out the Creating Filters section and don't hesitate to ask questions or for some help there...Most of the questions that people have may already have been answered there.....Best tip is have fun.. smile:D
Deathtop
Texture Master
- LMAO!
Sounds good thanks. I've been looking at several filters now some sure are complex just because there's so much going on! I'll have to work my way up that level of creation. For now simple but effective and fun will be my zone. smile;)
Stretched 2 Fit!
Hi and welcome Deathtop ! Don't worry my friend, I'm sure you'll be able soon to show us your futur wonders !
Have fun by playing with FF ! And come back here with your créations. You can open a new thread just for you and add your own work.
Have a nice Tuesday
24 unregistered users.
