purp1
I downloaded this, just for something different. I can get Metalizer to work with images. But the other ones just cover the image up. They don't blend or I can't find a way to use layers. Is this because its the free one? smile:?:
Those are just textures....If you do not see the lifesaver that means that an image is not used with that certain filter......Take a look at the library and look at those.... smile;) smile:)
purp1
so what do you do with the textures? i hate to sound st00pid but i'm really new at this. smile:cry:
textures are used a lot in 3d programs to cover or 'skin' a 3d object. i suppose they're used in 2d programs, too. so, if you made a wireframe object in a 3d editor and then wanted to cover the frame with something, you'd use a picture of a something. so, if you made a wireframe of a chair, all you'd see would be that wire frame, the outline. if you wanted the chair to be a wooden chair, you would cover the frame with a wood texture. it can get a little more complicated than that, but that's the simplest understanding of it.
FF makes two types of filters, textures and effects. textures are used as i've stated, more or less. effect filters create an effect of some kind on another image. a texture stands alone and is simply whatever it is, but an effect filters alters in some way another image. thus, if you had a photo of a dog, you might apply an effect filter which turned the dog green or another that made the photo look like an oil painting and so on.
and, i seem to recall that there are some exceptions to all this, but that's the basics.
purp1
okay , Thank You, I only have the stand alone versions. haven't bought the whole thing yet.
30 unregistered users.
