JKJ - Super Mashup by JKJohnson
http://filterforge.com/filters/10123.html
WOW !!! This is really excellent, awesome and amazing all the amount of possibilities that are built inside this filter !!!! I have just fallen in love with it smile;) smile:)
Very good and creative idea, and well done and with many possible option that change very much and modify totally the original base image
Great to have the source image into square divided by TRANSPARENT mortar(where you can put any background and make textured frames or any other thing) or solid color mortar division, and you can enlarge the mortar as much you want to even full nearly all the squares and just leave a little bit or the original image in small squares.
And also you can add a bevel and feather the borders
AND the square are not the ONLY shape, as you can also convert the corners to round ones and continuing they convert into circles !!!
And if this was not enough you can even change the hue tones of all the generated square randomly and get very good results.
BUT wait there is MORE !, you can even make one click AND all the square images ARE MIXED RANDOMLY, WOW !! Excellent.
Lovely, useful, great, powerful and creative.
Thanks really very much for this. I love it much.
SUGGESTION TO GO EVEN MORE BEYOND
Just one only possible suggestion, Could you also add to change the circle into an Hexagon ??? I think that this is more difficult so I do not think if it would be possible.
And even more, could it be converted the squares into trinagles ???
Here is one possible example but in this there is no mortar, so the mortar should be applied to this example
In this example above ONLY the light green triangles would be filled with the source image and the others would be with the mortar color or transparent.
And even more would be if you could make that both triangles (the upward and downward inverted) could be filling both triangles and then show ONLY the mortar in the edges of both triangles.
Probably it could be easier to make this other following triangular shape as they are much better for building the mortar
AND TO GO INTO COMPLEX WORLD smile:D
And to end I do not know if it would be possible to make also a complex shape with the mortar as shown for example below, so the white areas would be filled with the source image.
Of course, this is ONLY a suggestion and an idea I had, and it´s up to you if you want to make it or not, and if you like it, and if it would be possible.
30 unregistered users.
