Stylized Pine Tree v2 by Ghislaine
http://www.filterforge.com/filters/10084.html
Actually this is a suggestion, I think this filter should be submitted as an update to: http://www.filterforge.com/filters/10078.html
Basically here's the reason: the only addition in this update is the trunk, which can be included into the filter by adding controls instead of having a completely separate filter which produces a similar result. Unless there are major structural differences or version changes.
The only ADDITION is the trunk. For an addition, you are right. But the pattern or the effect is not the same. If you want a trunk in the first version, I will add one when I'll get time. But the v2 will stay as is. smile:)
Note that version 1 get a trunk. This update was submitted yesterday, 13th. But I do not see the new update today. Maybe it is for tomorrow. smile:)
Have a nice day guys !
