| Posted: November 6, 2011 2:31 am | ||||
very nice filter, I will have to make some tests to see how it works and the results I can get.
I would also like if it was possible in some way to have it also others "metals" in the same style as silver, gold, copper, bronce... |
| Posted: November 6, 2011 3:15 am | ||||
Rod_D
I will try and get that done for you asap. Rod
| Posted: November 6, 2011 10:57 am | ||||
Thanks very much Rod_D BUT is not needed asap, please, take your time and do it whenever you can and want, is not at all needed urgent, it was only a suggestion and not an order to do it.
As it seems that this is easy for you, I want ask if you are an alchemist that can convert lead or iron into silver or gold and you know how to use the Nuclear transmutations between materials If you are not a real alchemist, you are a real filter forger that have the great power to transform the images in whatever way you want http://en.wikipedia.org/wiki/Nuclear_transmutation Nuclear transmutation is the conversion of one chemical element or isotope into another |
| Posted: November 6, 2011 1:12 pm | ||||
42 unregistered users.
