| Posted: October 24, 2011 2:25 pm | ||||||||
This looks very nice and interesting and gives a very good effect of the scratch effect so you can view the other side of the image, and could be combined with a special image in the back so it shows through the monster scratchs.
Could the scratchs be changes if you change the source in the filter editor ? I mean if you wanted to make the scratched in different size or sizes, o have more than 3 scratches, or have them more separated. Thanks very much. |
| Posted: October 24, 2011 2:31 pm | ||||||||
hd8fdkd
Thank you for comment, SpecRay.
In this version each scratch size can be changed by "Right Claw Scale", "Center Claw Scale", and "Left Claw Scale". But current version applies scale after distortion. Because of it, distortion level is different from others. I would like to fix it soon.
It is easy to change the source, but needs more render time.
It is simple, just add controls. If your intention is different from my answer, please comment again. |
| Posted: October 24, 2011 10:34 pm | ||||||||
hd8fdkd
| Posted: October 25, 2011 8:27 am | ||||||||
hd8fdkd
I updated this filter today.
It supports input image as shown in variation 1. http://www.filterforge.com/filters/10011-v1.html By applying this filter to the same image repeatedly, you can make more than 3 scratches as shown above. I added margin control options between each scratches. It is also able to control entire scratches size. |
| Posted: October 27, 2011 6:15 am | ||||||||
I have now got back to this filter and have seen that I did not remember that was well done and you can get good effects and can customize the scratches well.
And also is good idea to use the same source image after the FF result more times to make more scratches just by rotating the scratches and so mix them. |
| Posted: August 5, 2012 3:26 pm | ||||||||
24 unregistered users.
