lipebianc
FFF = Filter Forge Fan
Personality Construction by TBH-1138
http://www.filterforge.com/filters/9946.html
lipebianc
Fantastic, TBH-1138!
I'm also a great fan of the game!
(Is it just me or there also a very subtle optical grid illusion effect on the default preset? http://en.wikipedia.org/wiki/Grid_illusion)
lipebianc
Great (and fast too)!
WOW !! this is really very original and like neon graphics in very high quality, specially in high resolution.
This could be great as base to other filters too
Lovely. Thanks
What happens if you add a METALLIC look to this filter ? smile:)
And the eye looks much more like a wall sculpture with LEDS smile:)
And also in Red
For having this I have ONLY changed the RESULT component inside Filter Forge and put it as "surface" and added SAME to source and height, and then changed the settings in the result component.
And one more
And WHY only have plain unified colors ???
Why not add your own multiple colors through images loaded ?
And what about adding an anemona red flower with black background ?
And lots of small color flowers ?
And using a tipography collage
And why not create NEON half shapes too with the same typography collage and changing the eye to the lines?
And making a fan with multicolored lines ?
To be able to use images INSIDE the filter I have JUST ONLY changed the color 2009 input component for the new Color control 2012 and put "images allowed", that is all.
For this last one I have take out the glow adding a levels component and changing the source lighting.
Also added the levels result to the reflectivity in the results component so it takes out all the metallic effect.
lipebianc
Fantastic examples, SpaceRay!
As always, SpaceRay takes the filter to a whole new level with his examples smile8)
Thanks very much for your comments.
smile8)
YES ! smile:D I am a creative person smile:D Thanks, I have the vision and power to see something and see in how many possible ways could this be used and not keep with the NORMAL AND USUAL way to use things.
And also now I am learning little by little to use the filter editor, and this gives much greater possibilities, as it happens in this filter, that all the examples are by changing something and modifying the filter with the Filter Editor.
I am very sorry that all the usage done on this filter is lost for the author and will not be submitted to FF.
Tim2501
Filters: 63
Very nice. Since I'm a mapper for the source engine myself, I know a few people who are working Portal 1/2-mods.
I took the liberty to recommend this cool filter to them, so it might actually give faces to some of their cores.
I'd love to see this filter updated with even more varieties of "Personalities" though smile:)
24 unregistered users.
