lipebianc
FFF = Filter Forge Fan
stary eyed by voldemort
http://www.filterforge.com/filters/9796.html
lipebianc
Preset #2 is my favourite! smile:)
(It should be the default one!)
voldemort
voldemort
Filters: 649
Somehow Missed this one Thanks for the comments --Im not sure that a different preset is worth forcing users to update their copy
You can simply click on preset number 1 to load it then select add preset and it will add a copy to the end and you can delete the first preset and have number 2 as your own personal first preset then
Maybe when ff3 comes out if i use the new outline component to update this one I will release an update with your preset suggestion since then there is also added functionality
lipebianc
Ah, don't worry with that! smile:)
It was just a suggestion (based especially on how the preset #2 reflected perfectly the filter's name for me).
Thanks for the tip and congratulations for the filter!
