lipebianc
FFF = Filter Forge Fan
Dartboards by meyendlesss
http://www.filterforge.com/filters/9704.html
lipebianc
Excellent! Very realistic! smile:)
Congratulations!
Totte
Ubernerd
Filters: 107
Simply brilliant Meye.
hehe, love it!
Very smile8) ...
I have just found this and this is really perfect and very realistic well done with the realistic metallic look and as shown on the presets you can easily change the colors and have many different commbinations.
And if you think that is only circular, you can change it easily to a square using Shapify by uberzev as shown here below
And if not wanted square you can also use other shapes
I have just found this awesome filter again and think still that is really great and that have thought that originally it was done as a realistic dartboard and apparently it could not be used for other purposes, BUT is wrong as I have thought that it could be also used in 5 other ways and even mix them together
WAY 1 - REPLACE PLAIN COLOR WITH IMAGES - Instead of the plain colors it could also alternatively be used bits of images filling the shapes in some creative way
WAY 2 - USE KALEIDOSCOPE - as this is a perfect shape you can try to use the Kaleidoscope component to get other unusual and abstract shapes that are made from the original one
WAY 3 - CHANGE THE SHAPE FROM CIRCLE TO OTHER ONE - In previous post I told and tested that is possible to modify the original circular shape to another geometric shape
WAY 4 - USE THE RESULT AS BASE FOR ANOTHER FF FILTER - You can render the result and then use it as a base source for any other filter from the library to modify the style of it, or create something different
Also it could be used as source for bomber component and have lots of different boards in a artistic work
WAY 5 - MULTIPLY THE CIRCLE AND MAKE A COLLAGE OR PATTERN - You can also instead of having just one single dartboard, have multiple ones, maybe in same or different sizes, and maybe using different colors, or arranged to make a pattern.
Also you could have multiple dartboards in different colors and sizes and use blend modes to combine them
MIX OF WAYS You can also additionally mix the ways together and choose the amount of ways you may like and COMBINE them together to create even more things, for example, change the shape to a square, and then use Kaleidoscope and then replace the plain colors with images, or just use two of the ways together, you decide
ANIMATE IT - Now in FF11 and FF12 you can also animate this and make it rotate or move sideways or vertically
So this is not ONLY a dartboard, you are using FF and it offers a great potential to create any other things
