Gene S Morgan
Filters: 81
Gene S Morgan
Filters: 81
I really like this filter. I make backgrounds a lot and will work good with other filters to make cool backgrounds. I would have liked a saturation node at the end for more color control.
Gene S MorganMy Webpage
Chazzy
Chazzy
Filters: 28
Glad you like it!
I'll look into adding the saturation node at the end for you!
Chazzy
Chazzy
Filters: 28
Updated: it should be available by tomorrow. Let me know if it proved useful to you!
Gene S Morgan
Filters: 81
Thanks for the update. You did not have to do it just for me, but it is better I use an update to your filter than change it myself. This way you get credit for it when I use your update.
Thanks much Gene
Chazzy
Chazzy
Filters: 28
It was a pleasure to do, and it only took a few minutes to update and upload.
Gene S Morgan
Filters: 81
Just wanted to let you know that I have posted a graphic I designed that uses your Blocky filter in the gallery section of the forum ..... Gene
28 unregistered users.
