jitspoe
Filters: 27
jitspoe
Filters: 27
Doing a blur on a bunch of noise is slow. Any ideas on a faster way to get the average color?
----There's a module under *External* called -Average Color-, perhaps that could be used ? (I don't have FF2, so I can't look inside this filter to see if I understand what you are asking for/about, I'm just going by the exact words/wording you've used.)
Nice plaster filter!
Yes there is a way to get approximate average quite fast (and the precision is adjustable).
I attached a modified version with the approx. method.
Basically I reduce sample rate before blurring (makes the blur step faster) and then only look up the center sample from the blur (since its an average color, we can use a sample from any location).
Note that the Checker component must be set to solid fill. Increase Repeat H and V to increase precision and lower speed. Decrease to get better performance/lower precision.
The reason why I used inclined setting is to reduce checker alignment with the box blur.
If you want to compare speed with the original approach, make sure you reconnect the blur inputs on every test (otherwise you'll be tricked by FFs caching)
Plastered - Sphinx.ffxml
W.B.
W.B.
Too slow rendering,or perhaps my poor cpu smile:(
24 unregistered users.
