Ken
CameraKen
Filters: 16
Ken
CameraKen
Filters: 16
Thank You for Downloading my Advanced Sharpening Filter. I hope you find it useful.
Sharpening in RGB can cause colour artefacts. This is eliminated with this filter by sharpening only the lightness channel in Lab. The colour is untouched.
Another problem with sharpening is that normally everything in the image gets sharpened. Again this filter overcomes this by using an edge mask. Only the areas chosen with the mask will be sharpened.
Sharpening increases the contrast between light and dark areas. This can create light and dark halos. This filter provides two sharpening sliders so that the lights and darks can be controlled separately. In most cases the darks can be sharpened more than the lights.
How to Use.
Open an Image and zoom out to see the whole image.
Check the Edge / Image checkbox to see the sharpening mask
Adjust the top two sliders so that the edges to be sharpened are black. Everything that is white will not be sharpened.
Once you are happy with the mask then uncheck the Edge / Image checkbox to see the image again.
Zoom in to an important area of the image
Now adjust the light and dark sliders to sharpen.
Please use the ‘Show Original’ Checkbox to see the difference between before and after.
If you have any comments or suggestions please post them below.
Ken.
Knight81
This filter is great. I do have a suggestion.
When I use a high Edge width the edge becomes blury. But it is more black, gives me great edges. When I set it to a small widht it becomes more sharp. But it is more gray, gives me blury edges.
Is it possible to make the edge more black when I user a small with. I can export a image with only the edges and fill in the area or sharp it so it becomes black, and then burn the org image with it. But maybe would be possible to add this to your filter?
The-any-Key
15 unregistered users.
