ronviers
lighter/generalist
Circuit Wall by Skybase
http://www.filterforge.com/filters/7749.html
@ronviers
ronviers
lighter/generalist
This is excellent. smile:) I never noticed that blocks could look so much like pipes and tubes.
@ronviers
Nice and well done texture, specially when changing the base color that gives shades that looks like glow over the surface, and this is also good as source texture for adding others additional textures over this one using blending modes.
And here is a textured version I have done in Photoshop adding two layers of rust with soft light blend mode and adjust the fill and opacity.
And you can also multiply the result of the filter and duplicate the circuit walls texture layer and have two of them, flip vertically and horizontally and blend this with the others.
soho
One of the best filters
I write through the translator.
