Nice and simple smile:)
I took a look at the construction: you use four High Pass components! One is enough: uncheck the Monochrome option and it will process RGB seperately. You then place the Extract RGBs after the High Pass along with a Desaturate (Weighted Average) and you have all four outputs similar to your current construction smile:)
Thanks Sphinx for the speed tip. smile:) It's been updated.
24 unregistered users.
