Vintage Twisted Thorns by cfree68
http://www.filterforge.com/filters/8905.html
Nice work, but I think it can be simplified by getting rid of the Surface mode in the Result component (obviously, this will require some work).
cfree68
colin Fizgig
Filters: 23
I thought about that. However, most of the shading actually comes from the surface mode and ambient occlusion. Without that it would look very flat.
I realize I could probably create the same effect with some clever gradients and masks, but I like the control that the surface lighting effects give for quick tinting and shadows. (well not so quick since they are slow to render smile;-)
I may try to work on some sort of Ambient occlusion faker that could use an alpha to create the same look. If I get there, then I could take out the surface node.
Thanks for the input smile:)
colin Fizgig
i would seriously vote this for an EP if it werent for the overlaps showing through each other again.
Being a fan of swirls smile;) I like this one... smile:)
cfree68
colin Fizgig
Filters: 23
I like the overlaps. I did notice that there were some inputs that had no control that were causing the transparency, otherwise you should be able to turn it off. I resubmitted with the controls for those inputs and changed a preset to show it without the transparent overlap.
here's an example.
colin Fizgig
14 unregistered users.
