Maze by Skybase
http://www.filterforge.com/filters/8852.html
You should use a small radius Median component at the end to smooth out the corners.
Genius. Update planned with it.
EAdams
Wonderful maze filter. Thanks to Betis for the tip about the Median component - it works perfectly to smooth the corner ends.
EAdams
I agree with you that although this is a very simple maze, is a wonderful filter in itself for making this kind of patterns in a simple way, and this could be used also as maps source images for loading it on other filters and also to blend this using blend modes with some images or photos
13 unregistered users.
