High Quality Brick Walls by Game Design Planet
http://www.filterforge.com/filters/8693.html
I really don't say to much about brick...Its brick.....But you have a nice look going on this one... smile:)
Targos
Game Dev
It is a good version. I just wonder if the bumpmap is inverted?
Cheers
AC
Game Design Planet
Filters: 4
No the bump map is fine, but it really depends on the look your going for. I set it up so the mortar jets out from the wall more then the brick. Personally I Just use Filter Forge to help create diffuse maps and then custom design all the shader maps.
GameDesignPlanet.com
_____________________________
GDP, welcome to FF smile:)
a couple notes on this one: too much distortion for 'new brick'. new brick is very regular and shows no particular distortion or warp. and, the brick itself needs more varigation and variety of noise. i'd suggest adding a perlin noise to the brick to kind of grit it up a bit more.
with all the brick filters in the library, if you want this to be used much you really have to make it quite good any more. otherwise it just gets lost in the all the others.
Game Design Planet
Filters: 4
Thanks Craig for the feedback, Some good points you have presented. I allow full control over the distortion so you can actually tone it down to nothing if your making freshly laid brick. Most brick has less noise distortion but there are some cases where brick layers get crazy and over mortar so I used the distortion to simulate over mortaring. As for the color variation and grudge that will be in the next update. Once again thanks for the feedback its always good to hear opinions from a fellow filter forger. smile;)
GDP,
well, i hope i wasnt too harsh, first filter and all. looking forward to the update.
50 unregistered users.
