Vladimir Mikhailov
FilterForge, Inc.
Filters: 4
zoom snippet ffv2 by voldemort
http://www.filterforge.com/filters/8457.html
Vladimir Mikhailov
FilterForge, Inc.
Filters: 4
Cool filter.
To avoid the error at zero Scale, you can set the minimum value of Scale in some small value less than 1
hmm, does it also do enlargements?
This is wonderful!!
Although, I felt like the snipplet was complicating a simple problem. Here's a solution with 2 nodes and 1 controller. I didn't want to make another snipplet that did the same thing so I'll post a small tutorial here.
smile;) Once again, great stuff! Inspired me to construct this.
voldemort
voldemort
Filters: 649
Thanks for all the wonderful replies Actually I submitted 2 versions of snippets with the same function to illustrate 2 different methodologies
the simplest one uses only 1 component (bomber) and works excellently
I like to release multiple versions like this because different mehtodologies give different insights
so
TO SKYBASE -------
PLEASE - PLEASE - PLEASE release your version as well differnt mehtodologies only help increase the general knowledge pool
this isnt an ego contest for me but more a contribution of knowlege in the gpl type spirit
High five. smile;)
Try setting the image to particle mode, then you can skip the clipping.
Now THAT I didn't see. Oh well, another snipplet is born!
