Plating texture by Igotaway
http://www.filterforge.com/filters/8278.html
It's a fairly simple design, but I like it. smile:) There's 3 unused components in it, a Stones & Perlin Noise going into a Blend, none of which go anywhere and can be removed. Other than that, it's still pretty slow, you might lose a Perlin Noise or two and just double them up, cause at such a tiny size (600 X 600) all that detail is lost anyways. You could probably halve the render time. Just a couple ideas.
