| Posted: August 17, 2009 7:21 pm | ||||||
I guess nobody saw this one yet? I think it's nice.
| Posted: August 17, 2009 7:24 pm | ||||||
oh, that's really good!
| Posted: August 17, 2009 9:01 pm | ||||||
nice one cf, it's one of the least explored areas [ frames ] of FF only 77 and only a hand full are really good, a handfull + 1 counting yours
| Posted: August 18, 2009 2:09 am | ||||||
Thanks Indigo.. Heres the filter with a mask for just the rails instead of the whole image.... Old Wood Frames RAILS.ffxml Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: August 19, 2009 9:09 am | ||||||
Thanks Craig..
Thanks Carl and yep its one of the least explored...From the different types and shapes of the moulding to the wood and textures used...Just a couple of favorite places to visit for frame samples.... http://www.engelsenmoulding.com/shop/...?catid=180 http://www.larsonjuhl.com/ http://shop.geminimoulding.com/index.php?cPath=27 When going to the first one use the search at the bottom and select "description" then you can type things like gold or burl...Good samples there... btw the engelson is my favorite one..Really close veiws of the moulding types.. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: August 19, 2009 9:17 am | ||||||
Fausto
Posts: 1 |
Every time I try and use this filter on an image I get the image overlapping one side or another.. So the frame is there, tiled twice but the image that I'm attempting to frame isn't entirely surrounded by frame.. Three sides are fine, but the fourth isn't. I've tried this filter in FF3, FF4 within Photoshop and standalone.. In all instances the very same result.
Any idea how to prevent FF from tiling the preview each and every time I try another preset? Talk about annoying! |
| Posted: July 7, 2016 7:04 pm | ||||||
As described in this post this filter works with square images only....I even included this in the "About" tab in the filter......You can do a work-around by rendering a size that is the biggest size of your image....Then use photoshop and chop it like a real frame....Here is an example I just did in Photoshop.......You will have four layers with each rail on a layer and then your image on the bottom layer making that five layers.......
![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: July 8, 2016 11:03 am | ||||||
| Posted: July 8, 2016 11:04 am | ||||||
What is this filter?! This is garbage!
| Posted: July 9, 2016 2:12 pm | ||||||
| Posted: July 9, 2016 5:22 pm | ||||||
