souxsi
Posts: 17 |
| Posted: June 27, 2009 5:33 am | ||
souxsi
Posts: 17 |
These are amazingly real looking, *thank you* Here is an example of use:
[img]http://farm4.static.flickr.com/3397/3665117818_78f0981a6c_o.jpg" width="512" height="512" alt="Vyctoria 02" /[/img] |
| Posted: June 27, 2009 5:50 am | ||
| Kurt Rickerd |
I added a drop size control slider for more versatility. It was added to the cells component, remapped 125 minimum, 250 max. In addition I changed one of the blend nodes from color to normal and relabled the transparency slider to opacity to make the water opaque if desired. BTW the index of refraction for water is 1.33 not 1.
| Posted: May 2, 2010 3:55 am | ||
Affinity Jack
Posts: 22 |
Sorry this might be a silly question but how can I have a transparent Background?
Filter forge 6 Thank you, Bill |
| Posted: January 10, 2017 7:16 am | ||
Does this help? I had to modify the filter slightly.
Remember to also load an image with transparency or create a new image with transparent fill color. _T_Rain Drops Hard Shadow Transparent.ffxml |
| Posted: January 10, 2017 9:17 pm | ||
Affinity Jack
Posts: 22 |
Wow Thank you Very Very Much! It helps big time...
I'm very new to this and tried to change... I'll get it sooner or later.. I'll see what you changed Thank you Very Much |
| Posted: January 10, 2017 9:22 pm | ||
