divi
Filters: 3
brickwall with vines by divi
http://www.filterforge.com/filters/7383.html
divi
Filters: 3
hi everyone smile:) it's my first filter and i learned a lot while making it. just submitted an update with improved look to the bricks aswell as more settings and a small performance boost.
cheers
Hey, welcome to the wonderful world of Filter Forge! Not too shabby for your first! smile:)
One general suggestion, which you might have covered in your update, is to give the users a little more control over the output of the filter. For example, you have one color control. You should first of all give it a name based on what it does, like Vine Color. Then you can add one for the plastery material and another for the bricks.
Another suggestion is on your filter tree. To create the brick area in the middle, you take the vines, blur them, do a threshold, blur them again, and then do a noise distortion. Avoid long chains with blurs (especially with a large radius); They make your filter slow, and really there's not much point to them if you are just going to distort them afterwards.
I'll be waiting for your update. Keep forging!
divi
Filters: 3
thanks for the reply smile:)
about the control components - i only really understood what they were for after i submitted them. smile:D so yeah, they are included in the update.
the blur chain was something that bothers me too, but the problem is that the first threshold is already at 100, so i used the first blur and the second threshold to reduce the size of the open patch further (there is probably a btter way to do this that i havent figured out yet smile:|. the second blur appears to be necessary to give the plaster depth. will have to experiment a bit more with it... smile:)
cheers
