Zoltan Erdokovy
Filters: 24
Bump tool by Zoltan Erdokovy
http://www.filterforge.com/filters/2110.html
Zoltan Erdokovy
Filters: 24
Here is a reference sheet of the controls:
BumpTool reference
And here is a short tutorial:
Derived texture maps - Part 1
Derived texture maps - Part 2
This is handy.
Looks good.....gotta check this out.....tough to get rid of the peak/transition creases in the bmps.....
ferret
FeRReT
Filters: 3
Wow thats amazing man, very well done!
princess111
I tried this filter in filter forge 3.0 and it doesn't work. I am upset about it not working, because I really like this filter. Nothing happens when I sel ect it fr om my list.
Well, I have to say that this works perfectly on my own FF 3.09 version.
This is a quick test using preset 1 without changing any setting
Perhaps you can delete it and download it again.
OR probably also it can be that you are using a high resolution image and it takes some time until you see something, and it could seem that nothing happens, but FF is processing the image.
princess111
Hey SpaceRay,
Thanks for the advice. I pulled this filter up without having an image open. That could be what the problem is.
Let me try opening my image first and see what happens.
princess111
Hey SpaceRay,
I installed this filter again and opened my image. I chose this filter from the list and nothing happened. I still can't figure out what I'm doing wrong.
Do you have in the Menu - View --> Preview Size --> Reduced activated ? or is it actual ?
Try to use any of the built in images first instead of your images to see what happens
In my case, when I open an image, nothing happens until a minute later (or more) if I choose Actual, and even choosing the built in images (600 x 600 ) in reduced mode it takes some seconds until something happens and begins to show it
By the way I want to give my thanks to you for discovering this very well done, interesting and useful filter, I did not know it and now as I have been trying I like it much.
This is the source Art in the round by CFandM
princess111
Thank you so much SpaceRay smile:)
That's what the problem was:
I am very happy. This filter works. If I viewed it in a larger size, it did not work and I did not see anything happening. What I had to do was view it at a smaller size. It took awhile to see it take effect.
princess111
This is what I did - I had the view on actual and I did not see anything until I changed it to reduced. I was using the built in image of the lifesaver, before I realized it was a view issue.
princess111
Hey SpaceRay:
Were you talking to me?
YES, thanks to you I now know this well done filter.
princess111
Hi SpaceRay, smile:)
Your very welcome. I liked what this filter looked like, the moment I saw it, within the Filter Forge filter list. You gotta admit, it's different.
Thanks SpaceRay
Zoltan Erdokovy
Filters: 24
Thank you SpaceRay for handling the situation!
I'm glad you guys found the filter useful. smile:)
khaz
This is simply awesome, cheers smile:)
Zoltan Erdokovy
Filters: 24
Oh by the way the new link to the documentation is
http://www.zoltane.com/pages/filter-forge/bump-tool/
