Whitedove
Miss Congeniality
Whitedove
Miss Congeniality
Kochubey,
LOVE IT!!!
Donna smile:)
Kochubey
Filter Forge, Inc.
Filters: 77
Thanks Donna smile:)
How about updating this filter to use the new Frame component? This will make it work correctly on non-square images.
Kochubey
Filter Forge, Inc.
Filters: 77
I'm working on it smile:bunny:
Ken
CameraKen
Filters: 16
Hi Kochubey.
Have you found a way to make the horizontals and verticals have a different pattern?
Ken.
very nice, kochubey!
ken, yes, this is possible. i use a 5 color gradient with a profile gradient and step curve. make 4 of these and rotate the profile gradient to make each side of the frame. blend these together two at a time and set the blend filter to opacity 100% and lighten blend mode. join the resulting two the same way. then, plug this into the 'margins' node on the frame component and there you go.
in fact, you could make each side have a different look if you had a step curve for each side. i just used two, one for the two sides and one for the top/bottom.
i just got done with FF so i'll post the screenshot the next time i have it running. i didnt use this in my own 'frame forge 3', but i've incorporated this into a new version i'm working on. the only thing i havent figured out is how to make the joins between horizontal and vertical sides have a bevel. that one may be beyond me.
craig
The reliefs, wood grain, and matting are excellent on this one.....nice work!!! smile:)
Kochubey
Filter Forge, Inc.
Filters: 77
Thanks StevieJ smile:)
ahimsa
Filters: 41
You did a really good job on this. smile:)
