correct step gradient snippet by voldemort
http://www.filterforge.com/filters/6993.html
Nice the insides smile:-p
I was almost going to congratulate you on finding a very cool solution to the problem. Only the spacing isn't quite right (see attached image). With five steps you'd expect 20 percent steps. I attached a threshold to check this and the first threshold step occurs around 17. In the attached image (the threshold with the attached profile) you will want the steps to be evenly spaced in the vertical direction as well.
You're almost there though...
I'm not sure if this solution is exactly correct but it looks like it. I found by manually adjusting a frequency component that (when frequency is set from 1-2) the frequency itself would amount to .5*(1/steps). Now I don't know how to get 1/steps but with a little trial and error it seems a bias set to 98 does the trick.
Then again... no this one doesn't fit either... set steps to 100 and you'll see why. I'll just post it anyway to give you another approach.
correct step gradient snippet.ffxml
voldemort
voldemort
Filters: 649
Thank you for the reply to be candid I would have never noticed that
your absolutly correct to the naked eye it looked dead on but when I measured it on screen (the default preset of 5 steps) the two end steps on the right where thicker
Ill look in to correcting this when I get a chance may be a bit since My workload in recent months has been huge
Gotta love the econemy theese days --allways more work for less money
Oh wait... I got it (when I was at the toilet smile:D ). Since the maximum amount of steps is one hundred the minimum value of the bias should be one (one hundredst). Just checked it with a 20000x20000 image.
(yeah I'm very busy with my work to,... but I just can't get problems like this out of my head smile:-p)
voldemort
voldemort
Filters: 649
Way to go --your fix your credit time for you to submit it --great work and brilliant stroke figureing it out
Hey you started it... just update it.
40 unregistered users.
