Single Image Stereogram by GXPILOT
http://www.filterforge.com/filters/6896.html
Gotta say I love it! But it's very very slow. I took a look at the inside and there are various things than can be speeded up. I'm still untangling the actual 3D part, I can't help but feel it can be way faster. This must be possible in just one offset.
I'll get back to you when I get my head around this stereogram technique. Correct me if I'm wrong, but it looks like the left side is just a repeated pattern while the right side is a repeatedly offsetted pattern.
Two things that you can speed up already: I have no idea why you use a circular gradient to create a sphere, but that can be done much faster/easier. Plus I've attached an easier way to create a cube.
Perspective cube.ffxml
Well, I couldn't figure it out completely...
but I did manage to get it faster.
Single Image Stereogram _ clean_VI.ffxml
GXPILOT
Those are examples they dont need to be used
But they do slow your filter down.
Your default preset takes about five minutes to render completely, and that's mostly because of the anti-aliasing (1:45 without).
The spin-off I posted takes about 40 seconds (12 without anti-aliasing). That is about eight times faster.
I not only re-routed the cube and sphere.
First I removed all 'redundant' components, among which was a Refraction component (those are slow). Then I replaced most Threshold-Blend combinations with a single Threshold. Read the wiki page Optimizing Filters for Speed.
Then I made the pattern so that it will always tile correctly on the lowest surface (with Seamless Tiling turned on).
You're free to do whatever you want of course. But with a 800% speed increase I'd consider an update smile:-p
this one is nice
12 unregistered users.
