Wobbly Tile Nudge and Tweaker by blurtsmum
http://www.filterforge.com/filters/6574.html
I wonder if you could make some sort of tunnel with the perspective going on here...
blurtsmum
Kay Patterson
If you load a preset with the middle missing you can tweak the end nudge to a smaller distance point -- If you want to do something similar but use your own image as the surround then Image Circle Nudger is the same filter essentially without the pre loaded pattern -- Image Circle Nudger
Working on some graphics at Project Isabella Graphic Workshop
http://projectisabella.com
