| Posted: October 30, 2008 2:18 am | ||||||
Koh
Well this warms me up with temperature going down and freezing in my office as the heater won't work! spring,summer, really a great filter!
| Posted: October 30, 2008 4:33 am | ||||||
Good work as always Sjeiti..Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 30, 2008 6:31 am | ||||||
yup, HU very quickly. i'm somewhat surprised it hasnt gotten an EP yet.
| Posted: October 30, 2008 9:03 am | ||||||
+100 Nice work......should get used alot!!!
| Posted: October 30, 2008 10:18 am | ||||||
Nice!
| Posted: October 30, 2008 12:34 pm | ||||||
blurtsmum
Wow I have learned so much examining that under the bonnet! Thanks. Very impressive and makes some pretty flowers!
Working on some graphics at Project Isabella Graphic Workshop
http://projectisabella.com |
| Posted: October 30, 2008 2:53 pm | ||||||
| Conniekat8 |
Beautiful!!!!!!
| Posted: October 30, 2008 3:04 pm | ||||||
thanks
I'll work on it some more to get the fluffy stuff more realistic and correct the height map to do away with that upper and lower ridge |
| Posted: October 30, 2008 3:08 pm | ||||||
Clap clap
| Posted: October 30, 2008 4:37 pm | ||||||
infiniview
Awesome! nice work.
| Posted: October 31, 2008 7:05 pm | ||||||
Nice! I really like how the center turned out. Flower pedals look good too, not sure about the glossy appearance though (looks as if they're wet or coated with lacquer or something). Btw you should check out the threshold clipping trick - with a few strategically placed thresholds the filter renders twice as fast.
| Posted: November 3, 2008 7:14 am | ||||||
| jffe |
The plastic-y looking petals are kinda weird to me, and FF can't handle the inner seed detail at 600 X 600, but as usual, this is totally amazing work Sjeiti.
jffe Filter Forger |
| Posted: November 4, 2008 4:58 pm | ||||||
Hmmms... the crux is probably in the word 'stratecigally'. I spend some time replacing stuff here and there with thresholds, only to make it slower . Where exactly should I place those? Did you test that with this filter?
I'll turn tweak the reflection some more, petals reflect light a bit weirdly. |
| Posted: November 5, 2008 6:31 am | ||||||
you could probably just turn up the reflection blur, sjeiti, and that would dull down the reflections a bit and make them more natural looking. now, if the filter isnt a surface type, then i'm all wet
| Posted: November 5, 2008 8:15 am | ||||||
I think the diffuse map is pretty cool as well. You could probably do a non-surface filter with this.
| Posted: November 5, 2008 2:36 pm | ||||||
Ok then, perhaps a little more than a few.. I attached an optimized version, and here I'm not only using the thresholds for clipping, but also for blending and set alpha operations. The result is not 100% identical, but very close. Sunflower Sphinx.ffxml |
| Posted: November 6, 2008 5:33 am | ||||||
| jffe |
The anti-aliasing pass takes just as long, but the first render pass is double speed at least.
| Posted: November 6, 2008 12:36 pm | ||||||
ronjonnie
HU 200%+!
Beautiful I love it! Ronjonie zazzle.com/Ronspassionfordesign*
So much to learn, so little time. |
| Posted: November 18, 2008 11:37 am | ||||||
mkultra72
Posts: 28 |
Incredible. Thanks.
| Posted: June 20, 2010 2:17 am | ||||||
48 unregistered users.
