Cheerios v2 by Indigo Ray
http://www.filterforge.com/filters/6527.html
Note: I need some help getting rid of the cheerio bumps on the bowl. Everything I tried so far ended in failure...
----I got this far with it (see screencap below, it shows the only change I made, an added bevel profile set to 22/0/0), maybe you can use this method or something like it and sort of the rest. smile:D
Jffe (you got some interesting image fx filters), thanx for the idea, but I actually found another way around the problem. I think I tried what you did but I didn't like how the cheerios were shadowed around the edges. Unless that actually is a good idea...
Anyway, I ended up using my handy "circle perfected" snippet to create a "size 75" circle, using that as the new "set alpha" for both the height and the color, with another size 87.5 for the color to keep the background blank.
This update should come tomorrow smile:)
----Thanks, at the time I had no use for textures at all and they seemed very odd to me (although I kind of get the idea these days a bit more). I guess I was more into 'warping' pictures for the most part smile:p (Aka - Krae/Stevie disease ha-ha)
----I was just bored last night and kind of intrigued by the edge/cheerio/bowl overlap problem so I messed with it for 15 minutes. No worries if you have a better solution, that usually happens for most people I think, but I know I always appreciate a kick-in-the-butt-with-a-bad-idea to get me moving toward a better solution ha-ha. smile:D
18 unregistered users.
