Ah... really nice this one. Well done!
I opened it up, and I'd like to give a few pointers:
You can do without the 'variation control'. Variation is always present in all filters right under 'size pixels'. Controlling variation the way you did only comes in handy when you have multiple 'noise components' you want to control separately. What would be nice though is a control to the 'Noise Scale'.
For speed improvement on the 'Noise Distortion'. You've kept the default values for 'Roughness' and 'Details'. These default values are somewhat misleading. I won't explain in detail why, but in most cases it's best to set 'Roughness' and 'Details' to similar values. And lower values are best for speed.
In the Multiblend I see you blend three images with values 30, 60 and 90 respectively. Any particular reason why you didn't use 1/3*100, 2/3*100 and 100?
I fiddled around with it a bit, maybe a nice idea to replace the Multiblend with two regular Blends and put in an extra IntSlider to control the BlendMode.
Also maybe nice: to first offset the image thrice, and then run them through three (similar) Noise Distiortions.
...but other than that great job smile:p
ps: oh yeah... that last offset 'Adjust Horizontal/Vertical'. Maybe it's better to hang those two controls onto the Offset of the Kaleidoscope.
Digiart
New, lost, but hopefully learning
Filters: 9
You downloaded it? I actually thought no one was downloading my filters, as when I looked at other peoples filters I see "Downloads" with the amount they've been downloaded next to it, but when I look at mine there isn't anything so assumed no one liked them. Because of this, some of my filters have been altered to increase their appeal (they are currently in the submission queue)...
Thanks for taking the time to look at my filter and offer suggestions for improving it!
Not really, no. Just what I came up with at the time really.
I'll look at adding your suggestions. This will help teach me better ways to do things in Filter Forge.
Chaotic and unhinged
33,849 Registered Users
+7 new in 7 days!
15,392 Topics
+44 new in year!
13 unregistered users.
