Lathe Custom Profile by ThreeDee
http://www.filterforge.com/filters/6425.html ![]() Steve
| Posted: September 22, 2008 1:32 am | ||||||
I couldn't wait to see how you did this.....
![]() Steve
| Posted: September 22, 2008 1:34 am | ||||||
Ah I knew it! You use motion blurs to create a horizontal distance transform like output - excellent! You should publish a snippet fully dedicated to the depth map part of the filter..
| Posted: September 22, 2008 1:59 am | ||||||
and for some rather amazing examples of this filter, check out this thread: http://www.filterforge.com/forum/read...#nav_start
| Posted: September 22, 2008 4:09 am | ||||||
ThreeDeeForge.....
![]() Steve
| Posted: September 22, 2008 10:08 am | ||||||
Hehe. The most obvious solution, of course.
Thinking about it. Question is, is it too abstruse of a subject without the full filter? You will only need it if you are using a pre-made (outside of FF) profile. The method for an internally created profile is simpler. |
| Posted: September 22, 2008 10:13 am | ||||||
Well, the snippet would ofcourse have to use an internally constructed "demo" profile, but I think it would be rather useful with the boiled down version that only creates the depth map. In that snippet you can concentrate on getting the best result from various profile types (varying thickness etc). |
| Posted: September 22, 2008 10:55 am | ||||||
+1 on publishing a cleaned up/boiled down snippet!
| Posted: September 23, 2008 4:43 am | ||||||
Snippet submitted.
One thing that may not be obvious is that if you create the profile in FF, you don't have to go through all these hoops to do the lathe operation, it is a simpler deal. (Of course, creating the profile in FF may not be...) Do we need another snippet or two to demonstrate how it works from an internal profile? You can create an internal profile with gradients and curves, for instance. |
| Posted: September 23, 2008 5:46 am | ||||||
Another fun thing to do would be to make a version which revolves around the z-axis. That would be equivalent to looking at this shape from the top. Would be good for car tires, clock faces, toruses (donuts, hoola-hoops!), plates and such.
I think I just talked myself into doing it... (so many ideas, so little time!) |
| Posted: September 23, 2008 5:52 am | ||||||
Yup. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: September 23, 2008 10:41 am | ||||||
Okay -- lathe from internal profile snippet coming up.
| Posted: September 23, 2008 12:38 pm | ||||||
