Redcap
Redcap
Filters: 100
Plasattack! by KGtheway2B
http://www.filterforge.com/filters/6383.html
Redcap
Redcap
Filters: 100
A good filter! A diamond in the ruff as it were, except this diamond is a beat up wall smile:)
ah, lathe and plaster; cool!
KGtheway2B
KGtheway2B
Woot, got ep!
congrats, KG smile:)
Redcap
Redcap
Filters: 100
Now that it is EP can I make a suggestion?
Note the wood and how it changes color, even though it is the "same board". I understand that it is because you used tiles to make the wood, but it is strange seeing wood three different colors just because it passes behind some cement.
I would suggest using repeating curves and gradiants to get the wood to be the same color. Just a thought.
Cheers!
Great filter all the same.
KGtheway2B
KGtheway2B
Thanks for the suggestions Red-
I just submitted an update that should resolve the issue.
I removed the Hue Sat Lum variations from the tile components so the wood will now be uniform in color. My monitor setup is pretty bad so I never noticed the differences, thanks for pointing that out. When creating it I actually tried doing gradient generated wood planks but it didn't play well with the rest of the filter so I just left it as tiles.
