Numerology by ThreeDee
http://www.filterforge.com/filters/6187.html
Cool, it's like a pre-Matrix Matrix look, not quite ascii art, but a cool in-between of the 2. smile:D
Very cool!!! smile8) smile8) smile8)
Could do ones and zeros for that old bit print too.....
this is one i'm tempted to look under the hood at.
Me too... smile;)
I have just found this filter that I had not seen before and shows an clever, creative, awesome and amazing way to create realistic numbers in 2008 when it was not available any text input like there is now available with the text component
So now in 2026 it could be made a new variation using the text component and using any font you may like where you could put any number, letters, alphabet characters and even dingbats
A special thing is the clever and very interesting way to see HOW the numbers on this filter are distributed according to the luminosity or luminance of the source image lighting when considering that this was in 2008, so Threedee was very advanced and expert to know how to do this in such early date
Also is very good that each of the numbers is tinted and using the original color from the source image that makes it shine even more
This may be very old but is very good to learn and know how to build filters in a such creative, expert and clever way and surely helped other people
NUMEROLOGY ANIMATION
And additionally there is something that was impossible in 2008 and now you can animate the numbers for example modifying the luminance of the source image as shown at the animation shown at the end of this post
OTHER VERSIONS IN 2020
Numbers by Luminance By Mehmet Sensoy
This is also creative and well done and uses a different clever way to distribute creatively the numbers using bomber component instead
I like more the colorful version of ThreeDee, This is another version that is based on a similar way of showing numbers with luminance but only in just one single color and the size of the numbers are also reduced in size according to the luminance
Luminosity Photo Mosaic v1.0
By Mehmet Sensoy
This is a weird, interesting, creative and cool way to use image bits that are distributed according to luminance in some way using the source image
and it can also additionaly be used the luminance for some weird, unusual artistic ways to distribute the image bits as shown here above
Here below is the Numerology animated version fast test using threshold variation from 0 to 100
