Another technique example, based on two profile gradients and one threshold component...
Curves.ffxml
Lucato
FF addicted
Actually, it should be "Curve To Shape III", the second one was from Uberzev hereUberzev here. ;0)
Anyway nice job Sjeiti. Your main system just has one node more than Uberzev has.
Lucato
FF addicted
Nice technique Constantin, send this as snippet to the commyunity. ;0)
Ah I missed that one. Ubers version is simpler (but quite similar) and a bit faster. So I'll just delete my version... if that is possible. No use having snippets around doing the same thing but slower smile:-)
I did a speed comparison including Constantins version. Mine is the slowest, but I can't make out if it's Constantins or Ubers that is faster. The rendertime msg shows different results each time: sometimes slower, sometimes faster.
