Fast spiral by Sjeiti
http://www.filterforge.com/filters/6027.html ![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: August 6, 2008 1:44 am | ||||||
Very interesting! I'm going to have to take a closer look at this one...
| jffe |
As we inch toward fractals....Nice work.
jffe Filter Forger |
| Posted: August 6, 2008 1:49 am | ||||||
Incoming update with a parallel gradient, for even more fractal madness.
(ok... back to my snails... finally) |
| Posted: August 6, 2008 4:23 am | ||||||
Some interesting stuff is possible with this one...
| Posted: August 6, 2008 7:45 am | ||||||
| Posted: August 6, 2008 7:47 am | ||||||
| Posted: August 6, 2008 7:48 am | ||||||
nice one, sjeiti
| Posted: August 6, 2008 7:52 am | ||||||
| Posted: August 6, 2008 8:47 am | ||||||
| voldemort |
Added alot of simple options
mirror gradiant rotate gradient etc real simple modifications and simplifications This is the most Ive been excited about FF in a long time
here are the presets for my mod of it and the file to go along in case your interested Fast spiral-vold-mod y1t.ffxml lets all whine for a wine port |
| Posted: August 6, 2008 9:00 am | ||||||
Sweet!
Good mod, volde! I'd use an 'angle' control slider for the 'Rotate Spiral' functionality though. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: August 6, 2008 9:10 am | ||||||
| voldemort |
This one adds Some INSANE!! options but is more control complex
Fast spiral-vold-mod u1t.ffxml lets all whine for a wine port |
| Posted: August 6, 2008 9:15 am | ||||||
| voldemort |
As you will see with this more complex mods though Some of the most intriqueing patterns Ive seen hare can be generated
| Posted: August 6, 2008 9:16 am | ||||||
| voldemort | ||||||
| Posted: August 6, 2008 9:21 am | ||||||
| voldemort |
Great ones yourself Crapadilla
Really like some of them Oh yeah Great job on this one Sjeiti Really clever lets all whine for a wine port |
| Posted: August 6, 2008 9:22 am | ||||||
Thanks, just wait untill you see the update, should be good for another few hours of fun.
The top and bottom presets are similar, but the direction of the gradient is 90 degrees in the other direction. Imagine what happens if you feed that in here. |
| Posted: August 6, 2008 9:41 am | ||||||
| voldemort |
My modeifications allow for the rotation allready by pluggint the effect into an elevation gradient using a standard gradient with offset
also allows for directionals switch as far as spinning it 90% all you need to do is place a check mark on the phase of the initial curve with two settings -66.6 +66.6 works like a charm also mirroring the gradiant is fun also by plugin in a step curve you can isolate the swirl easier lets all whine for a wine port |
| Posted: August 6, 2008 9:52 am | ||||||
Very interesting!!! Gotta try this one out on manipulating lighting.....
| Posted: August 6, 2008 2:46 pm | ||||||
and, if you want to expand this a bit further, try adding a kaleidoscope after that last set alpha in volde's mod. you can get some interesting, sort of architectural patterns that might be useful.
Fast spiral-vold-mod sjeiti rev 1.ffxml If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: August 6, 2008 2:59 pm | ||||||
| Posted: August 6, 2008 8:39 pm | ||||||
The stupid thing is I originally started all this to make to make a roll of rope. I got stuck with that and somehow got onto the snail track. But now, whith the two spiral types, it should be relatively easy to do a rolled up rope. Unfortunately it's all work and no play for me at the moment
oh what the hell.. just a little then |
| Posted: August 7, 2008 4:56 am | ||||||
ah, cool. it needs a touch more roughness/grain, but very cool
| Posted: August 7, 2008 8:44 am | ||||||
Yeah... I know... but I can't play all day. I'll tweak it some more tonight, if my girlfriend lets me (last night she actually said: "Who's more important, me or your Filter Forge snails?").
| Posted: August 7, 2008 8:53 am | ||||||
oh oh, you've entered the 'true addict' phase of FF! prepare to lose the gf, your home, your job, your life and all things otherwise pertinent! ![]() If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: August 7, 2008 8:55 am | ||||||
| Posted: August 7, 2008 9:01 am | ||||||
.....and of course you said FF, right??? Nice update!!! Steve
| Posted: August 7, 2008 12:20 pm | ||||||
Good start there... and I'm looking forward to the filter! --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: August 7, 2008 12:41 pm | ||||||
ScaryKitty
Ooooh, yeah! Again with the wonderfuls!
Kat
----------------------- "Listen, gotta dash, things happening. Well, four things. Well, four things and a lizard." -The Doctor |
| Posted: August 11, 2008 11:54 am | ||||||
KGtheway2B
With some work- these spirals could be a cool ionic topper for a roman column filter. I'm not sure I could finagle with things enough to get a decent result myself so I invite and encourage anyone to use my filter as a base (if it helps at all).
| Posted: August 19, 2008 4:46 am | ||||||
