Administrator |
| Posted: June 16, 2006 10:41 am | ||||||
Administrator |
Beautiful!
| Posted: June 16, 2006 10:42 am | ||||||
Administrator |
A minor problem with the normal map -- the bubbles are shaped conically:
http://www.filterforge.com/filters/505-normal.html |
| Posted: June 16, 2006 10:43 am | ||||||
| Posted: June 16, 2006 11:27 am | ||||||
Lucato
I'm gonna kill you Crapaaaaaa!!
You've started that! I'm gonna check all your maps! Heheheh. Vlad, I'm gonna try to fix that too. |
| Posted: June 16, 2006 2:27 pm | ||||||
hehehe, bubble wrap! how cool, lucato. would have never thought of if myself
craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 16, 2006 5:19 pm | ||||||
Lucato
Thanks Craig.
Does anybody has a tip about how to get rid of the f[beep] 'shaped conically'? Btw Vlad, the Result Component or other that has 'Height' would has a 'Height shape' where you would select CONE or SPHERE! |
| Posted: June 16, 2006 6:45 pm | ||||||
Very nice, I'd just like to note that 'real' bubble wrap is tiled in a hexagonal fashion...
http://www.virtual-bubblewrap.com/ima...00x600.jpg Make something like that and you've got a winner. |
| Posted: June 16, 2006 10:18 pm | ||||||
LMAO
I guess its a linear gradient somewhere that creates the conic shapes in your height maps. Use a bias or gamma curve instead. Ideally, the profile of this curve should be a quarter circle. This way, you would get a perfect hemisphere in the height map. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: June 17, 2006 4:21 am | ||||||
Lucato
That's a plot now! |
| Posted: June 17, 2006 8:44 am | ||||||
Lucato
Thanks for the tip Crapa, I've tried the Contrast+Bias, but It still doesn't work very good. Well, I've changed the structure and created new controls: Now, you can use it as texture or as effect over your image. You can control the bubble wrap color, increase or decrease the number of bubbles, change its state and bubble wrap side. In sum, I'm sending an update of my Bubbles Wrap (texture) and the version for effect. So, stay tuned in folks! |
| Posted: June 17, 2006 8:49 am | ||||||
