Turned out well smile:) I prefer preset 7 to the Default as default..... ahh it's all personnel taste smile;) smile:)
I'd recommend variation 6 as the default, as that one is the most interesting looking. smile;)
6 is good too smile;) smile:)
Beliria
lol, thanks guys. I had trouble picking which to set as the default. And I know Dilla likes number 6 smile:D, part from had already sent the filter in last week before I started posting some of the images. Mind if others rather a different variation as the default I could resubmit it. I would say with the light effect but I think that would really be another filter cause it looks different to some degrees anyway.
i like the default, #1 and #7.
Just swap the two presets around and resubmit smile;) I mean it not like anyone is pushing you smile:dgrin:
Beliria
Well, am thinking, of updating with the light effect addition, but not sure if that would be classed as an update or new filter, part from I have managed to set it so you can turn the light effect off so it looks like the original filter. That and added a repeat to the elevation gradient so that you get more metal texture effects, all most like an engraved metal when the repeat slider is in the higher figures.
Doing a test run on res times at the mo. Then have to think about the issues with light colours.
smile:D so 2 choices, minor update (change presets around) or mega update (additional functions) smile;)
Hey, looks good!!! smile8) smile8) smile8)
Beliria
Okay these are the possibles for a major update.
All the following are variation 6 thats been tweaked with new functions. (Will still be able to create as is as well)
with added rust (which has control features to increase detail, change the angle, colour etc)
Beliria
Variation 6, with metal fold and rust. All rendering times are around 4 minutes for a 512x512 size image.
Beliria
variation 6 with just metal fold added.
Beliria
Variation 6 with rust and red lights. Took 4 mins and 50 seconds to render. Not sure if I should add all the above extra features plus the light feature. Think if I disable the folded metal the rendering time goes down by about 1 min.
Let me know what you all think on this matter, and then I'll submit the filter as an update smile:D.
I like where you are going with the texture on the first and last one..... smile8) smile8) smile8)
I tend to agree with Steve [ yeh it happen once in a blue moon smile;) ] for your render times maybe you could turn off the Anti-Alaising on the default preset - it may or may not look good, give it a try, it will quarter your render time [ possibly ] smile;) smile:)
Beliria
Well if you guy's all like 1 and 4, I can drop the metal fold from that filter.. and just keep that version for me hehe...
That will cut down on the rendering time a fair bit too. Well by 1-2 minutes that is.
Yep and even less if I hit anti-aliasing to off.
Will do a few more tweaks then send it in tomorrow, unless someone else has said, No I like 2 and 3 as well... smile:D
Whoa, that one is GREAT! Bloodvine-covered Ivory towers were always my absolute favorites! smile;)
Beliria
hehe am trying to see the ivory in that one... smile:D.
Thanks for the comments though Dilla! So do you think them will be worth the rendering time?
That depends on the machine you obtained those rendertimes from.
Beliria
um..
here is my poor machines info
1 gig ram
3.8+ amd 64 Athlon.
ati 600 pro graphic x256whatsit
and some other stuff...
Beliria
So.. comparing your machine to mine.. render time for you will be a blink of an eye smile;) smile:D.
Anyway, have sent in the updated version and has been accepted smile:D. I left the original presets in the 20 you can send in, but changed some of the first 9 variations around including the default.. smile;) This is when I get a.. maybe you should put number whats it as the default instead? smile:eek: smile:D
While your result is not speedy, it is on the safe side...
Vladimir Golovin wrote elsewhere:
The current limit is 15 minutes per image / map [on] a single-core P4, 3HGz, 1 GB RAM.
Beliria
yay go me! Thats pretty close to what my computer is I think lol...
So long as I keep them under 10 mins rendering time I should scrape in that time frame..
