Hi, you could use the metallic map input for more of a metal sheen smile:)
you should talk to Ronviers he's into maya as well smile;)
Kodras
Filters: 2
I'll look that one up smile:) two weeks to make a 3 minute 3D narrative, nightmare smile:eek:
in some ways, some of the presets look more like brick that normal brick filters. so, that's kind of interesting. but, i dont like how there seems to be a break in definition between some of the bricks, like, they arent quite well defined brick to brick in places.
Kodras
Filters: 2
Ah but are any two bricks exactly alike smile;)
Just trying to make it sound deliberate tbh, this was the result of applying random filters with a general goal in mind and seeing what came out
hi kodras,
umm, what i meant by definition here was that some of the bricks were hard to discern where one left off and another began. and no, no two bricks are exactly the same smile:)
Kodras
Filters: 2
ah yes i see what you mean now, I might have a fiddle with it and see if I can change that, as well as trying out metallic mapping
well, you mostly only see this when the brick size is larger. on the smaller walls of bricks, it's not very noticable and could even pass for worn bricks. so, not a biggie smile:)
35 unregistered users.
