Rotate 90° by Quasimondo
http://www.filterforge.com/filters/581.html
Mario, great snippet! The only problem is that it won't work on non-square images when Seamless Tiling is turned on -- that's why we didn't include the rotation component into Filter Forge.
Quasimondo
Quasimondo
Filters: 32
Well, it should be common knowledge already that certain techniques do only work with square images. But I should add this as a note to the filter description.
I still hope that you will find some kind of fix for this in the next update - what about my proposal to use the length of the bigger edge of an image as the maximum pixel size instead of the smaller one?
32 unregistered users.
