MetalGrate by Zoltan Erdokovy
http://www.filterforge.com/filters/594.html
Zoltan -- fantastic work! My only recommendation is to make it brighter:
Also, replacing the black areas with transparency would be nice.
Quasimondo
Quasimondo
Filters: 32
That's an outstanding creation - wow!
Lucato
FF addicted
Hey Zoltan, amazing job! Congratulations. Just a comment. I'm not sure if It is my monitor or are my eyes, but seems a little blur the final image. I'm not sure if applying a sharpen would get a little better. Anyway, It's a stunning work!
Zoltan Erdokovy
Filters: 24
I'm glad you like it. smile:)
Vladimir: good points! The new version is on its way.
Now you can play with ambience color to make everything darker/brighter.
Added transparency and a related thickness param.
Lucato: Hmm... I didn't notice any blur... can anyone second this?
The simplest way to inrease the Brightness on the Lighting tab -- that's what I did for my example above.
However, the right way is to fix the diffuse map, i.e. the branch is connected into the Surface Color input.
Just approved the update -- excellent work, but I still think it needs to be a bit brighter:
Zoltan Erdokovy
Filters: 24
Thanks Vladimir! smile:)
Hmm... how would you define the proper brightness? I tried to avoid clipping at the high end of the histogram.
28 unregistered users.
