KGtheway2B
KGtheway2B
Normal Map Channels are Offset Maps by Richard Bartlett
http://www.filterforge.com/filters/1477.html
KGtheway2B
KGtheway2B
I was hoping this would be the answer to my concerns but it doesn't seem to result in the same normal maps that filterforge generates from a height map. Does anyone know a way to generate a normal map from a height map within the filter without the results component?
Here's a modified version - its not 100% similar to the FF output, but its close...
Normal map Assembler.ffxml
Answered you in the other ("I need help") thread on this.
MKBreuer
MKBreuer
Filters: 47
Hy!
Here´s also another Version.
It´s combine external Diffuse with an painted Height-Map.
This can be control over the High-Pass.
The Idea was to see how it works as Normal when you changing the Map.
Just simple, but not simpler. (A.E)
MKBreuer
MKBreuer
Filters: 47
I forgot:
The Normal Channel that I used based on your Filter!!! smile:)
