| Posted: April 23, 2008 2:47 am | ||||||
| Posted: April 23, 2008 2:48 am | ||||||
Ron, excellent use of the HDRI images!!!
| Posted: April 23, 2008 9:36 am | ||||||
ronviers
How could something bad happen from pushing a button so colorful and shiny.
Thank you Steve. @ronviers |
| Posted: April 23, 2008 10:37 am | ||||||
Looks good!!!
| Posted: April 23, 2008 11:36 am | ||||||
these look good. i like that you added a glow. i still think with a little twist here and there, you could easily do jewelry, gems and such.
| Posted: April 23, 2008 3:23 pm | ||||||
ronviers
I just realized this is pretty messed up. The lighting inclination slider does not work properly and it will not be easy to fix. I also want to release a version that does elongated shapes. I do not have time to fix either problem right now. It does what it does just fine, otherwise I would pull it, so get whatever use you can from it and I will release the corrected two versions when I get a chance.
Edit: Ok, I have decided to pull it. I will add a link to it in this thread if you want to use it as is. This thread will remain in the forum library even after the filter is removed so just search for shiny coloured buttons. I will submit a the better version when I get some time but no telling when that will be. Shiny Coloured Buttons.ffxml @ronviers |
| Posted: April 23, 2008 3:24 pm | ||||||
22 unregistered users.
