Spherify/Un-Spherify uberEDITION v3.0 by uberzev
http://www.filterforge.com/filters/1762.html
Time to put this into test...
I tried to make a "light rays" filter with the earlier versions, but it turned out that the "spherify" part wasn't accurate enough.
Let's see how it works out with the uberEDITION.
Yes, the spherification is accurate -- fantastic!
(And the method you used to create the angle gradient is a work of art in itself!)
Most awesome work. Thank you.
Time for me to buckle down and update about 100 of my filters that use this.. smile:D
Another nice update to an essential part of snippeting... smile:)
Just one point... I noticed the Frame component in there. This will break any filter with size/pixels lower than max. Maybe you should remove the Frame and insert a Tiles and a Caleidoscope.
+1
11 unregistered users.
