Nice effect Ron smile:D This is only a personel taste thing and it possible works better on different pics, some of the presets are just a bit burnt out with the white areas - I'm sure others would disagree smile;) This will be an HU smile;)
ronviers
lighter/generalist
Carl wrote:
Nice effect Ron
Thank you smile:)
That was an oversight - thanks for bringing it to my attention. Apparently whatever ThreeDee is doing with the 'Proportional Gradient' snippet changes the distance between the image plane and the environment - and I thought I didn't understand it before. smile:| I will back off on the HDRI brightness and resubmit. I will hold off a couple of days in case someone else catches something I can fix. smile:)
@ronviers
Hey Ron, nice effect!!! It will come in handy!!! smile8)
ronviers
lighter/generalist
Hey Ron, nice effect!!! It will come in handy!!! Cool
Thank you Steve. smile:) Keep in mind that the its counterpart offers more lighting control so if you have time to make the canvas adjustments and crop then that would be a better choice. Thanks for looking. smile:)
@ronviers
I'm really liking variation #8 for the "sunlight/shadows thru trees" effect.....very usable!!! smile8)
ronviers
lighter/generalist
Is it something you can share with the rest of the class? smile:)
@ronviers
ronviers
lighter/generalist
Here is one to demonstrate that it really does work on non-square images.
@ronviers
ronviers
lighter/generalist
From this smile:)
@ronviers
i like the default.
ronviers
lighter/generalist
i like the default.
Thanks Craig, I have submitted another one with presets that account for the differences in lighting between this one and the original. I hope that you will find more of them appealing – I left preset one intact.
This is one of those filters that could benefit from more environments.
Thanks for checking it out. smile:)
@ronviers
ah, good on the update smile:) and yes, environments would affect this. good point.
ronviers
lighter/generalist
I was considering replacing my two 'Add Atmosphere' filters with this one, but I wanted to see if anyone had an opinion about it before I do.
Edit: Never mind - going to work on it some more. smile:|
@ronviers
17 unregistered users.
