Foliage by ThreeDee
http://www.filterforge.com/filters/5242.html
Nice image application!!! smile8)
huh... not quite sure what to say on this one. the foilage look is pretty cool, but why follow the lifesaver pattern?
Mousewrites
Not life size.
So you can have selection based foliage. IE, you make a tree, and then select roughly where you want leaves, and run the filter.
That's what I'd use it for, anyway.
Exactly. If you have a tree without leaves that needs them, you just select around the area you need leaves in and add them. Say you have a winter-time photo and want to make it summer-time. Of course you would have to adjust the environmental colors of the photo, too, to make it believable. (The lifesaver is just the default image and selection. I don't see any great use for covering lifesavers in leaves either.)
