Hazard Stripes by KGtheway2B
http://www.filterforge.com/filters/5203.html
This should come in handy!!! smile8)
Maybe you should change the default to one of your other preset as it looks the same as Warning Stripes by Michael Tannock while your other preset look different smile;)
KGtheway2B
KGtheway2B
Update coming soon using voldemort's stripes method. I updated the lead preset to be more unique.
I've included the old one as an attachment here.
Hazard Stripes Original.ffxml
thank you for that, KG. i'm always hesitant about downloading updates due to losing something out of the original. so, i appreciate the attachment there.
voldemort
voldemort
Filters: 649
Glad My snippet helped got your comment on smoothing check out the stripe style slider thats what your looking for
if none of those preset curves work for you
take a gradient and plug it in the shape slot
even easier is to remove the wave curve and place the curve style you prefer
this was really meant as a snippet to illustrate
if you looking for a smoother or rounded --try circular arc or gain curves
to make it work you will need to turn mirror on and use the repeat slider in the final gradient
or use a curve repeat option
This turned out well smile:)
34 unregistered users.
